tj08 v ft03 v suggestion
anferne85
Hi, I looking at putting prolima megahalems and a 5770 silent into a case and it needs to be matx... after lots of research the only two cases that I can use seem to be the
ft03
and tj08.
im kind of leaning towards a tj08 1. for price 2. because i can have a led temp monitor on the front to keep an eye on things.
any bad feedback on the tj08 ? is the ft03 worth the extra $150 (incl slot drive)
any other suggestions ?
cheers guys
I don't know if you've looked at it, but an NZXT Vulcan will also just fit a Megahalems.
I second that, Vulcan is a great case and cheap.
It fits the Megahalem if you don't install the 200mm side fan (which was not supplied anyway)
ft03
and tj08.
cheers guys
There is a TJ08-E coming soon... so I would wait for it. And If you can't....mmmm, I think Megahalems fits onto a FT03, but not sure how much spare area you would have.
Sorry the Vulcan looks a bit ugly to be honest, according to the specs a megahalem will fit a fto3 by about 5mm. I hear the tj08e won't be out until April I hear
the vulcan may not be as pretty.. But its also 120 bucks cheaper then the FT03 (shipped prices from newegg)
I purchased the tj08 despite it being a really old case.
Looks like i might have a 5mm clearance on the cpu cooler and card. or less!!
il post some pics
I made the swap from a pck62 to a tj08 just because i was sick of the size of the pck62..
got a couple new thermaltake silent fans.. very happy with them..
The only thing i can hear now is the psu, a seasonic 620w which does seem a little louder than before, its probably the case setup or something...
everything cpu and gfx are passive cooled and fans on 800 rpm are something like 10 db so a pretty quiet system overall.
