HopkinsProgramming
- Jun 30, 2006
Hey guys!
If there is anyone out there who has a Silverstone TJ07 case, can you take some measurements in the case for me? I want to get a TJ07 this summer, and be able to put a 240 radiator in the lower section (beside the PSU), while keeping both drive bays installed.
From what Silverstone has told me, there is 245mm of space between the rear-most hard drive cage and the back of the case. The radiator I'm looking at (Black Ice Extreme II) is 274mm long.
I'm wondering if there is enough room for me to scoot both of the drive cages forward, so that the radiator will fit. From all the pictures I have seen, it looks like it could work, but I am worried that pushing the cages forward will put the front-most cage on the curve of the case where I may not be able to drill holes to secure it back to the case.
And yes, I do realize that it would be really easy to take one of the cages out, but I really want to keep them both in so that I can fill them both up.
Thanks guys!
Thanks guys!
