TJ07 mod would this work
gimpacause
hi guys well i've been pondering a new build for a while now and i've selected the TJ07, i know you can fit a 4x120mm rad aswell as a 2x120mm rad in the bottom but would it be possible to fit this 4x1200mm rad in the roof i understand i will have to cut a good portion of the roof out as i'm thinking top rad to cool cpu/chipset/mosfets bottom 4x120 to cool graphics and bottom 2x120mm to cool dominators with the tec module
would this work
or can you advise on a case that all this will fit internally
thanks guys
