tivo / computer tivo
Spearboy
i was reading a tread and someone said that you can set up a tivo system with an old computer. can this be done for free. sorry if this is talked a lot about. my google searches wern't turning up much info. The best i could find was something called snapstream. i want to use a tivo system of some sort where i can maintain normal quality of cable and still be able to watch the shows on my tv. i have an old crappy diamond stealth tv tuner card that i think only works on 95/98/nt but im not sure.
edit: is it possible to buy a tivo system and set it up via internet so that its free monthly
Other people are probably gonna have way more knowledge than I on this, but heres a quick run-down.
A regular computer with a tv tuner card can do this. I think ATI AIW cards have worked well for this as well. On top of that you'll need somplace to store what you record, so a large hard drive is necessary. The software needed for on-screen programming is available for free, though I can't tell you where. I just read this in Maximum PC. When I get home tonight, I will check the latest Max PC to see if its there.
if someone could reccommend a card that would be good to get for this setup and weather it would be good to setup this up on a crappy standalone computer or if i should set this up on my normal rig. also what kind of storage space am i looking at. will this look good on my tv. i have a basic 42" hdtv. and would like it to still look somewhat decent
I was just pricing out the difference between standard Tivo's vs. those for HDTV. I'm still not sure if there is a difference where the signal is processed, but one thing for sure you'll need a lot of HD space.
build a compter.
Put at the least a 30 - 40GB drive
Download "Freevo" and install.
done.
ive been reading up a bit and tivo supposivly offers a basic service which records and pauses live tv and has a guide up to 3 days in advance. not the best but does what i want it to. the question is does the tivo service work with any tivo box or only on mix setups (dvd + tivo). i cant seem to confirm any information and im at work and cant call tivo right now
edit: this service is free thats why im interested. dont want to pay 13.00 a month, im cheap
If you buy an ATI AIW card, you have everything you need. Well, a big hard drive is nice too. ATIs software works pretty well actually. BeyondTV and MyHTPC are also nice...the latter being free.
First off you need a tv tuner card. I would recomend a Hauppauge PVR-250.
Next you need some software. Try out snapstream's Beyond TV. I just got it and love it.
