Titan X SX600 Question
Stev3FrencH
Hey everyone,
I am looking to get a Titan X strapped into my M1. Min PSU requirements for it is 600w. I have a SX600 but I am concerned how close I am cutting it. I have a 4790k that is not overclocked, just running stock clocks. I think I will be fine running the hardware on a SX600, but if I wanted to overclock the Titan X at all is where I am not sure. Anyone running this kind of setup?
Stev3
Ohh wow alright sweet, thanks for the info. I should be all set to OC it for s&g's then id imagine too if it can handle two 980's.
Aibohphobia's set up will draw around 140W more power than yours at stock frequencies, so you should have a decent bit of headroom to OC with.
I'm running my Titan X off a 460W PSU. Overall wattage is irrelevant; all that matters is the ability to supply sufficient power to the card.
