Titan Fenrir
the.ronin
I recently picked a Titan Fenrir seeing how it seems to hold its own against the higher end tower coolers like the Noctua and True at half the price.
I’ve got it cooling an i7 920 D0 at 3.8 with stock vcore. Using Arctic MX3 compound and having run through a couple thermal cycles, I’m idling in the low 40s and bumping up 70C under Prime95 full FFTs.
With the EVGA X58 SLI LE and the CM Scout case, it gets pretty tight in there. I had to remove the top 140mm and relocate it to the front of the case as an intake fan. There is another 140mm in the lower front half of the case also intaking but blocked by 4 HDs. That leaves a 120mm fan sitting at the rear of the case as my single exhaust.
Just curious to see what others’ experiences have been with the Fenrir.
