Someone here mentioned the Titan Amanda. I like what I am hearing about it but I would like to confirm a few things.
I know that there is only one Titan distributor in the US, that is fine. High prices (~$70) are also fine. However, the poster claimed (and showed with his temps) that the Amanda had lowered his temperatures vis-a-vis his original aftermarket cooler by 10C. The Amanda has TEC (Peltier) correct? Would I get a big temp drop by going from a Sycthe Ninja w/64CFM fan to the Amanda? Further, the poster claimed that the Amanda generated less heat and the air coming off the Amanda was slightly below room temp. I would LOVE this because my computer being on and Folding heats up my college dorm quite a bit and me and my roommate don't like it. No, opening the window is not allowed as it causes the heater to think "It's cold in here" and add MORE heat.
Finally, I have my Opteron 170 at 2.6GHz with 1.50 BIOS-set vCore (1.35+.15, weird MSI settings anyone?). I cannot get past 2.6GHz on this voltage, 3DMark06 (which I use only for stability) locks up in Deep Freeze. No it is not my 7900s, I got that fixed a while ago. Do you think that I could lower my temps, up my voltage, and cool off my dorm room with this Titan Amanda? Thanks.
