TITAN/780 - Ubuntu Folding
Thanassos
Hi Guys,
I'm trying to get my dedicated folding box to run with my 780s in Ubuntu but I get no option for driver installation in proprietary drivers and installing them manually with the .run file seems to break my UI completely (I'm Linux noob)
If I dual boot with my main rig (690 GTX Display) with a 780 in slave slot both the 690 and 780 begin to get WUs no issue.
In my dedicated box I have 3770k + 2x 780s and running off of the on-board DVI-D Ubuntu can't see the 780s and so they're not installed/running in F@H Client, anyone know a work around?
Thanks for any insight, just trying to move away from Windows now that nVidia can as it keeps randomly crashing.
What does below terminal command return ?
Code:
lspci | grep "NVIDIA"
If something like "VGA compatible controller: NVIDIA Corporation GK110 [GeForce GTX 780]" it means it has been recognized in PCIe slot by kernel at boot and you only need drivers.
If it returns nothing try dmesg | grep "pcie" to see kernel boot messages regarding PCIE slot.
When card is recognized, you can proceed as below to install 319 drivers series (that shall be included in the Ubuntu 13.10 release)
Add xorg edgers PPA with below terminal commands :
Code:
sudo add-apt-repository ppa:xorg-edgers/ppa
sudo apt-get update
sudo apt-get install nvidia-319
Personnally I prefer the ppa method compared to running a shell, stopping lightdm and running the nvidia binary.
If it is a dedicated folder, you do not have to have the GUI running to run wine or the GPU clients. Try switching to single user or commandline mod and start each console in a separate virtual terminal.
When listing the GFX cards it returns NVIDIA TITAN for all 4 cards even though they're 780s. I assume that's a GK110 issue.
Installing like below works, but on reboot all GUI is missing CTRL+ALT+T works but errors keep poping up or windows appearing outside the screen. Also are they are the proprietary drivers? If not they won't work.
sudo apt-get update
402, thanks for the feedback but don't need wine as Core17 works by default in Linux and quite well. However Core17 only works in 7.3.6 (feel free to correct me)
Yes, they include the 319.32-0ubuntu1~xedgers~raring1 package that is a repackaging of the proprietary drivers in the Ubuntu framework, and more globally a bleeding edge repository that is useful when somebody wants to install drivers that are not yet available through regular ubuntu repositories (in your case, the 319.xx drivers shall be included in Ubuntu 13.10)
http://www.ubuntuupdates.org/package/xorg-edgers/raring/main/base/nvidia-319
Did you install all proposed packages after the apt-get update and apt-get install nvidia-319 ?
If yes you may want to follow some of the workarounds in this link that used to work when a driver upgrade is messing with the ubuntu desktop
