Hey guys,
I have a i5 2500k and an Asus P8Z68-V (original, not Gen 3 version). I had a stable overclock at 4.5ghz for some time, but I feel that many of my settings weren't optimal, and ontop of that even though I had my voltage lower, for the most time I was getting 1.35V. So I wanted to start from scratch with new overclock settings, and see if I can get 4.5hz with less voltage, possibly being more stable as well, although I've never crashed once with my past overclock.
So here it is. I am listing the settings in the ASUS Bios, so these settings may be different for other motherboards.
BCLK: 100.0
Turbo Ratio: by all cores
Multi: 45x
PLL Overvoltage: Auto
EPU Power Save: Disable
OC Tuner: Cancel/Off
CPU Ratio: Auto
Speedstep: Enabled
Turbo: Enabled
VRM: 350
Load Line Calibration: High
Phase Control: Optimize
Duty Control: Extreme
CPU Current Capability: 110%
CPU Voltage: Offset Mode
Offset Mode Sign: +
Offset Voltage: Auto
Adaptive Thermal: Enabled
Active Cores: All
Limit Maximum: Disable
Virtualization: Disable
CPU C1E/C3/C6: Enabled
I pulled these settings from a thread from over a year ago, so again I don't know if it is optimal, but it seems like a good start! I tested it in Prime 95 for an hour (I know I will test it for longer, I just wanted to get quick results:
Why am I getting on average 1.4v, which is higher than previously before? I assumed changing to offset mode would help the voltage. If not offset, how can I get the voltage down to 1.28-1.3v (which I have seen before for this cpu at 4.5ghz)? Should I change the LLC? Any other general tips you can offer me? Thanks guys
BCLK: 100.0
Multi: 45x
CPU Ratio: Auto
Speedstep: Enabled
Turbo: Enabled
VRM: 350
Offset Mode Sign: +
Active Cores: All
