Have been slowly collecting parts to watercool my pc and was looking for some
tips on how do it and make it look good.
The parts I have are:
lian li v1200b
pa120.3
3x ap-15s
heatkiller 3.0
evga x58 mobo/920
A few specific questions I have are:
1. What's the best and or easiest method for mounting the radiator to the top
of the case? Is there some kind of kit that could accomplish this, or just use the
old tape and dremel method?
2. What kind of pump/reservoir should I get with the combination of what I have?
I was considering something like a pump/res 5.25 combo but am weary of the power
of those pumps being a good combo with my radiator as I'm going for performance.
3. I want to cool my 5870 in that loop eventually as well, is this possible to do in
the same loop while still keeping things cool with slight oc?
4. Is watercooling the motherboards chipset worth it?
I know this seems like a lot of questions and I'm researching them on my own as well
but wanted to get input alongside my research of which direction I should head. I have
built a few watercooling loops in the c2d era but that was simply buying whatever parts
and putting them together without any real research. The machines would end up being sub par performing monstrosities which I wasn't really proud of displaying. So i'm looking to avoid that with this build and build something that will be of good quality.
Thanks!
lian li v1200b
pa120.3
3x ap-15s
heatkiller 3.0
evga x58 mobo/920
Thanks!
