Tips on stable e6600 at 3.4
ematsui
Hi,
First off my specs
e6600
p5b-e (old rev with no northbridge voltage chagnes)
2 gig of G-Skill DDR2 800
Im at 3.4 right now and failed Orthos at around the 3 hour mark on blend.
My vcore is at 1.45, memory at 2.0, timings at 4,4,4,15
Temps are idle at 37c and load at 53c
Do you think i should up my vcore (I know the P5B have vdroop) or up my timings or both?
Thanks
jucestain
Yea, give it one more notch of voltage. If my comp runs orthos + atitool for 6 hours I'm content with it since I'll never play on my comp for more than 6 hours at a time. Usually, if orthos passes for 30 minutes, one notch of voltage will make it pass for 2-3 hours and then another notch will get me 6 hours without fail generally. But that's just the general thing I've found.
