I've got a Dell Inspiron 6000 laptop, and the DC Jack broke on it. I got a new jack off eBay to replace the old one with. Last night I stripped down to the motherboard, and got to work desoldering the old jack, which is where I'm having trouble.
I'm using some desoldering braid, and a 15W Iron from radio shack. I'm slowly getting bits of solder off the 6 pins, but it's very difficult. The solder resists melting, and i have to concentrate the tip in an exact spot for 30 seconds or so, for it to liquefy at all.
Any suggestions for removing this component from the motherboard? I'm getting some of the surface solder off, but theres probably some within the holes as well that I wont be able to get to. Would using a higher wattage iron (30W?) be of more use, as it could melt the highly resistant solder better? I don't want to go too high, and risk damaging other components on the board.
Thanks
Thanks
