Here is a link to a thread I started on the evga forums about how I found out how to easily cool my GTX280:
http://www.evga.com/forums/tm.asp?m=466903&mpage=1&key=��
However, to sum up:
The GTX280 has intake ports at the front of the card, if there is a heat source right by these intake ports, the card will run very hot regardless of side/exit/intake fan speeds. If you remove the heat source so that cool air can draw in at the front, the card will run at very good temps.
In my case, I had the intake fan blowing over 3 WD HDD's with that heated air being sucked right into my GTX280 causing high temps. Nothing I did with speeding up side/exit/intake fans, etc would help. I moved my hard drives up above in the drive bays using rails, and then I had a drastic drop in temps. I went from 95C plaing crysis to never going over 80C after moving my HDD's up. And I live in PHX AZ so my computer den is always about 80 deg F in the summer. Several other users have confirmed my results if you read the thread.
This fix does not relate to an issue where your card immediately ramps up to over 100C regardless of airflow and needs RMA.
BTW, the GTX 280 is an awesome single GPU card and you don't have to worry about the SLI/Crossfire hassles (like vsync negating performance) with an X2 card.
However, to sum up:
