Tiny Secondary Display - Recommendations?
AlphaQup
Hey guys,
Recently, I've downsized from 3 screens down to my primary display in my signature, in pursuit of better audio. Loving it, but missing my HW monitoring :(
I'm looking for a tiny secondary display, one to take on almost strictly monitoring duties (OC stuff, temp, GPU/CPU usage, etc., maybe I throw a Twitch window over on there with a Counter Strike stream on it, etc) but here's the kicker:
- must be USB powered
- must take an HDMI in
- preferably one with a "kickstand" (worst case, I 3D print one, know some guys at work that could use it as a "calibration" exercise :D)
Ideally I'd like it around 12" in size or so, with enough resolution to be able to house GPU-Z, RealTemp, HW info, I think 1080p at the minimum would do the trick, 2K would also be fine.
Quick pick of the area and size I had in mind, ideally I'd like it to sit just to the right of my right speaker, next to my USB/HDMI on the side of my case propped up just nice. Run some 1' cables when I want to bring it out:
Any recommendations/experience you guys have on roughly 12" tablet sized USB powered displays?
Thanks in advance!
Thanks for the reply Baenwort , so what tablet do you run software on? I've seen the 7" tablets or there about's mounted inside the chassis, maybe I go that route instead. I do have dead space in this massive case I could better utilize and go with a more vertical full size monitor option.
I use old windows tablets when it is for someone else and my personal windows tablet when it is for me.
My tablet is a tough tablet from https://www.ruggedtabletpc.com/family-of-tablets-overview (I have the xTablet T8540 as it is IP67) and works well enough as a side monitor and as a bath tub Steam streaming end point. It also stands up to the kids and has a digitizer stylus that works well enough for my wife's drawing on the go. I like that it's always in use. We've had it for nearly 2 years now and it is still working.
I the beauty of using remote software control across your LAN is that you can use any cheap or handy to you device.
I like multipurpose unless it is something I use enough and exclusively. If I still gamed like I did before the kids I'd explore the hardwired monitors linked by DoubleTap.
There are tons of 10-13" LCD panels on Amazon that are USB powered and can take an HDMI input. It's hard to find objective information on them, but they seem decent for utilitarian uses.
https://www.amazon.com/Eyoyo-1920x1080-Monitor-Loudspeakers-Security/dp/B078K1HXQW/
https://www.amazon.com/Eleclink-Portable-Resolution-Monitor-Raspberry/dp/B071P32VHQ/
Thanks for the input guys, much appreciated.
I'm going to be looking into the tablet models first, and seeing what I could possibly find in the used market. Price-wise, the monitors linked by DoubleTap are about what I'm looking to spend. I agree, it's tough to see through the BS when browsing for low-end tech like this.
I do like the idea of a multi-purpose solution though, been forever since I've owned a dedicated tablet due to how much I'd think I'd actually use it. This might be the reason to get me back into using one.
The search continues.
