Activate: AMD
- Nov 6, 2004
I've got a bunch of hardware that I'm putting together, ostensibly for an HTPC. Everything is basically integrated in the motherboard (incl. msata drive) and I have a pico PSU that I could use to power it. the only other requirement would be the ability to install or modify the case to accommodate a single half-height PCIe 1x expansion card. Using a pci-e ribbon cable to do this wouldn't be out of the question.
to summarize:
Celeron G1610
Intel H77 mATX board
16GB ballistix tracer sport low-pro 1.35v ram
No PSU necessary
No drive cages necessary
No ODD slot necessary
Space to mod in a half-height card required
Closest thing I could find is the Coolermaster Elite 100 mini ITX/mATX case, but its no longer available. Anything in a similar vein? I'd like to minimize size in as many dimensions as possible. Height isn't as critical but I'd like to keep it within a half-height form factor. This guy over at SPCR is a good example of what I have in mind
EDIT: any ITX cases that can be easily modded to accomodate mATX boards that would fit my criteria better?
to summarize:
Celeron G1610
No PSU necessary
