Tiny broken fans
Darkstar850
I have an old machine that is currently running an Abit KT7 MB and a Geforce3 Ti500 video card. Both the little fan on the MB (believe it cools northbridge?) and the fan on the Geforce no longer work.
Can I replace these fans, and if so, what size (25MM?).
Thanks
I've bought a bunch of stuff from 2CoolTek and have always been treated right. He's got a bunch of replacement fans that should do the trick.
You could also consider a Tt "Crystal Orb" or something along those lines as a complete HSF replacement; I've done this in the past with good results.
Good Luck - B.B.S.
just mod some 120mm tornados on to them. all the real [H]ard people are doin it nowadays. :D
