That's not the probem. It was up to frame 50 last night until the power had a hissy fit.p[H]ant0m said:I've not noticed it on any of my boxen, as for some reason I haven't gotten any tinkers lately... but is there anything in the fahlog.txt file about whether the unit early ended and a new one was downloaded, and what amount of time are you using between checkpoints? The Default is 15 minutes I believe.
jfb9301 said:I've noticed this behavior with any WU. (it's particularly anoying when you are 90% done with a 600 point gromacs)
yes stanford uses savepoints, but if you restart the machine with the reset button and don't shutdown gracefully to restart, sometimes the WU will fail a "consistancy check" on the restart. If that happens you will start over from the first frame. This is not the same as being unstable and finishing early.
The [H]orde needs You!
echo off
cls
echo The FAH Backup System v1.2c
echo By BorisBorf (Cole Montgomery)
echo CBD Folding (#36974)
echo http://cole.montgomery.spymac.net/fah/
echo Configure to your liking!
echo A hint: Use Notepad's Edit/Replace feature! Ctrl+H
rd C:\FAHBACK\48 /s /q
ren C:\FAHBACK\47 48
ren C:\FAHBACK\46 47
ren C:\FAHBACK\45 46
ren C:\FAHBACK\44 45
ren C:\FAHBACK\43 44
ren C:\FAHBACK\42 43
ren C:\FAHBACK\41 42
ren C:\FAHBACK\40 41
ren C:\FAHBACK\39 40
ren C:\FAHBACK\38 39
ren C:\FAHBACK\37 38
ren C:\FAHBACK\36 37
ren C:\FAHBACK\35 36
ren C:\FAHBACK\34 35
ren C:\FAHBACK\33 34
ren C:\FAHBACK\32 33
ren C:\FAHBACK\31 32
ren C:\FAHBACK\30 31
ren C:\FAHBACK\29 30
ren C:\FAHBACK\28 29
ren C:\FAHBACK\27 28
ren C:\FAHBACK\26 27
ren C:\FAHBACK\25 26
ren C:\FAHBACK\24 25
ren C:\FAHBACK\23 24
ren C:\FAHBACK\22 23
ren C:\FAHBACK\21 22
ren C:\FAHBACK\20 21
ren C:\FAHBACK\19 20
ren C:\FAHBACK\18 19
ren C:\FAHBACK\17 18
ren C:\FAHBACK\16 17
ren C:\FAHBACK\15 16
ren C:\FAHBACK\14 15
ren C:\FAHBACK\13 14
ren C:\FAHBACK\12 13
ren C:\FAHBACK\11 12
ren C:\FAHBACK\10 11
ren C:\FAHBACK\9 10
ren C:\FAHBACK\8 9
ren C:\FAHBACK\7 8
ren C:\FAHBACK\6 7
ren C:\FAHBACK\5 6
ren C:\FAHBACK\4 5
ren C:\FAHBACK\3 4
ren C:\FAHBACK\2 3
ren C:\FAHBACK\1 2
xcopy C:\FAH\*.* C:\FAHBACK\1\Machine1\*.* /e
cls
exit
