chinspecial
- Sep 25, 2007
I have been looking around a lot and researching a lot. What I have come up with is that the a700's have better base and have isolation while the ad700 are open with a better sound stage, better treble, and better mids.
However, I'm a little worried about leakage on the ad700's, but about possible lacking in the sound quality or sound stage in the a700's.
I will be using them for music, movies, gaming and such, etc. I listen mostly to rap(classics and underground) and r&b though. So base is going to be a very important deciding factor in this. But is the difference in bass and sound quality enough to justify the differences for either?
Which would you guys recommend for my tastes? How's the leakage on the ad-700's? Any other cans in the 100$~ range I should be looking at?
