Time to worry 8800ultra temp
clone
This is after running cpu burnin on 4 threads and rthdribl at 2560x1600 in afr2 sli. I started this torture test because my system would just turn off during raid in WoW. I also ran a voltages log for my 850watt quad 12v rail psu by antec
3.23
5.0
11.84
time for water or am i being paranoid? the case has a lower front 120 and a up 120 on the back at the cpu area + the fans in the psu. I am UNABLE to turn up the fans on the gpu GG nvidia
Its a bit hot, use Rivatuner to set the fan speed to up/lower as temps rise/fall.
rivatuner does not work under x64 vista unless you f8 and disable signing and then even still it will not control a sli setup jsut the main carc :(
I would like to point out that you should probably get a multimeter for the votage tests, as a motherboard isn't very accurate at all.
Have you tried running the tests with the case panel off?
for temps not panel has been on so i can get real world
for the crashing issues last night in raid i tried with the panel off. i ended up having to take out one of the vid cards
the multi meter is in my brothers room he is still sleeping (2pm here) he was up all night pvp
lol riva tuner for gpu 0 set to 100% and ntune to set gpu 1 to 100% because in ntune it wouldnt set 0 rofls both are turning at 2.8k now. in about an hour i will get a base line
this is a update ss with temps with cpu and both gpu fans at 100%
new
old
cpu cores saw a improvment
gpu 0 saw a inprovment
gpu 1 no improvment i want to blame the lack of air under the card due to it being only 3/4 of a inch from the bottom of the case
Ton of heat in that case. Does your side cover have a fan? If mine, I'd add a fan to the side cover and maybe add taller feet to the case so I could mount a fan under the base to exhaust some of that heat.
my case front lcd reads 95F top of the case 94F bottom of the case. I do not want to mod this case as it is not well sutied for water cooling
no side fan on the panel
1 120 in
1 120 out 1psu out 2 8800ultras out
it is a nightmare this case is from three mobos ago its time to move on i am just trying to get all my p's and q's lined up before i drop cash on case, blocks, rads, pumps etc...
If you don't want to mod the case, I'd look at getting a desktop fan to blow into the case with the side panel off.
it wont help much there is somethign liek 25ghz in this room atm it is rather crazy
i am thinking about going with the dangerden water box and putting water blocks on cpu and gpus and leaveing north south passive as they are now
the last few days i have been taking hte panel off during raids and it has helped the temps a little
