Time to Upgrade a new System
maverick786us
I am planning to buy a new System with good for Overclocking and on the other side I have to keep the price also into consideration. Therefore i preferred to go for..
CPU: E6300-E6400
Mobo: Asus P5B Deluxe or Gygabyte DS3
RAM: 1MB DDR2-800 MHz from G-Skill
HDD: 160GB Sata from Western Digital
Video Adoptor: GeForce 7800
I would rather go for E6400 because it uses 8 Multiplexers over 7 MUX used by 6300. But if the price difference between these 2 is too much then I will go for E6300. What is your personal openion about E6320 and E6420? Since their prices are almost same as that of 6300 and 6400. In terms of perfomace, stability and OC how are these CPUs??
For good PSU and Coolant(most probably I will prefer Liquid Coolant) I need advice from you guys. Tell me what you think of the combination I mentioned above? Is the above combination perfect in terms of Performance as well as price?
I am not familier with the latest market price of these products so i will be glad if you tell me.
Thanks in Advance:)
