time to switch to team red! but is it worth it?
Discussion in 'General Hardware' started by Dan, Jul 11, 2019 at 10:24 AM.
  1. Dan
    Dan [H]ardness Supreme
    7,439
    May 23, 2012
    current system:
    intel i5-4670k @ 4.5 (cant get any higher)
    Shit Asrock mobo since my asus died
    Xfx vega 56
    5760x1080@144hz + 2560x1080@75hz.
    1tb SSD with 4tb 7200.
    games I play: Destiny 2, FFXIV, WoW, and occasionally Dab into other stuff.
    I want to buy a Ryzen 3600, Gigabyte b450 pro Wifi board. Ill need another 16gb of ram and a 240m Corsair cooler paired with it and OC'd as much as i can.
    I mean, are we talking like 10 fps jump in games? No idea where the ryzen 3600 can clock too but i heard it can compete pretty closely with intel in the IPC department. The upgrade itch is coming. I might scoop up a 5700xt within the next few months once its had some time to settle in.
    TheFlayedMan likes this.
  2. TheFlayedMan
    TheFlayedMan Limp Gawd
    322
    May 29, 2015
    Probably better off upgrading your graphics card for more fps in games. Nice set up though looks sweet.
    Dan likes this.
  3. Dan
    7,439
    May 23, 2012
    I will be getting a 1080ti/2080/AMD 5700xt in the next few months. my CPU is just dying to be retired currently though lol.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    12,844
    Oct 7, 2000
    you's probably see a decent max fps bump but i'd bet your minimums would come way up and then more with a new gpu.
    daphatgrant likes this.
  5. TheFlayedMan
    322
    May 29, 2015
    There are not many reviews of the 3600 yet but I gather it performs roughly the same as the 8700k.
  6. daphatgrant
    daphatgrant Moderator Staff Member
    17,646
    Jun 15, 2003
    Personally I'd grab a gpu first while letting the bugs get worked out of Zen2.
  7. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    1,990
    Nov 12, 2001
    I went from a xeon 4770 equivalent to a r7 1700x a while back and was a pretty lateral move on a 980ti, I would think the jump from that to zen 2 would be pretty good. There is a guide floating around these forums that shows the vrm of the current am4 boards, so you should be able to find a quality 4xx series board. I would guess that there will need to be a few rounds of patching to be up to x570 level.
  8. Keljian
    Keljian Gawd
    564
    Nov 7, 2006
    You named Destiny 2, grab a GPU, wait for fixes, or go 9900k. Having played WoW in the distant past, I wouldn't want a WHEA/bluescreen while raiding....
  9. Dermen
    Dermen Limp Gawd
    319
    Oct 10, 2017
    If OCing a lot the MSI B450 Pro Carbon has better VRM than the Gigabyte and the last time I shopped they were similarly priced. IIRC it has the best VRM on B450.
