WinnipegDragon
- Nov 25, 2005
Unfortunately, every fan in my case is loud, and there is now a baby in the house right next door to my office/workspace/headshot-factory.
Box specs are in my sig, and the case is a Nikao Dragonfire with 4 x Nikao 120mm Blue LED fans. These fans are rated at 24DB at 1800RPM, though I doubt that noise rating now. Also the Nikao fanbus that comes with the case SUCKS and needs to be replaced, perferably with something that lacks any audible alarm.
Having said that, the bigger noise contriubtors seem to be the fan on the Zalman and the northbridge fan on the MB.
I was looking at Coolermaster 120mm fans, which are cheap, rated at 22DB (and I think I trust Coolermaster here more) and with four of them the 20CFM less per fan is not such a huge deal. But I'm not sure what I can do with the Zalman and the NB fan.
Any suggestions on a complete fan re-vamp for this box?
edit:
One other concern on the NB fan. The eVGA card runs right over the NB on this MB so height of the NB cooling solution is an issue. I seem to recall there being a performance hit if you moved the video card to the other PCIe slot as well, but this might not be an issue anymore...
edit edit:
Yeah, the 2nd PCIe slot only runs at 8x but that's no big issue. I was thinking of throwing on the Zalman fanless NB47J cooler, it should get plenty of airflow from the case, and moving the 7800GT over. Also, the Artic Cooling Accelero X1 cooler sounds like it will do the job of quieting down the 7800GT.
Finally, has anyone had experience with the Enermax UC-9FATR2-B fanbus/card reader? I'm trying to find reviews or specs but I haven't found any. It looks like it might only support 2 fan connections?
edit:
edit edit:
