Sideroxylon
- Jun 7, 2004
Ever since I put my wc rig together several months ago, I've been thinking of a better way to do it. I'm thinking most of us here on the forums are the same way. The [H]ard are always thinking of ways to 'fix' things that aren't broken.
Here's a link to my original worklog.
Here's what I'm starting off with...
I'm going to try to put a dual hc in the front of my case. I think I can fit it in there by removing one of the 3.5" bays. It's going to be tight though. The hc is a little over 10 3/4" long and after removing the bay it will leave me a bit less than 11". We'll see...
My temps right now aren't bad 44c idle and 53c load. Not sure if you can see this very well but I have a pretty good kink in this hose. I'm sure that's not helping much. I'm eliminating my nb wb and adding a vga wb. Once I do that the tubing won't have to make nearly the bend that it does now. Just another reason why I needed to 'fix' my rig.
I'm going to have to reroute all my tubing and find another place to mount my pump. I'm kinda bummed about the pump. I really like it stashed away up there.
That's all for now. I'm gonna tear it all apart and start cutting now. Hopefully I'll be back up and running by tonight.
