tighten ram timings
jamestime88
i am trying to get the most performance out of my ram. i am using pc3200 kingston hyperx on a soyo kt333 dragon plus board with an athlon xp 2100+ @ 166x14 2.32ghz. i was wondering if anyone knew what settings i could change to make my ram perform better since its only running at 166mhz it should have some headroom.
these are my settings:
CAS latency = 2, changed from 2.5
bank interleave = disabled
precharge to avtive (trp) = 2T, changed from 3T
active to precharge (tras) = 6T
active to CMD (trcd) = 2T, changed from 3T
DRAM burst length = 4
dram command rate = 2T command
dram access time = 3T
dram que depth = 4 level
Dram twtr = 3T
write recover time = 3T
so what is it that i could change to make ram more efficient? should i just generally try to lower everything, or should i not mess with it? thanks for the help
