I am about to order something from tigerdirect using 8% bing cashback, how do I know I will get it when I check out, I followed the link but it shows nothing when checking out.
Make sure you're using IE. Or the IE tab in Firefox (if you're using firefox)
the cashback you will receive should appear before you add the item to the cart. It will be right under the price.
