Ozymandias
- Jun 21, 2004
... you enable TCP/IP filesharing on the OS 9 computer. Otherwise, it'll throw up the error: "The file server uses an incompatible version of the AFP protocol. You cannot connect to it." However, you still can, even though Apple dropped Apple Talk in Tiger, for reasons unknown. Here's a guide to turn on TCP/IP filesharing (just follow step 2: Activate TCP/IP support for file sharing) and then you should be OK. I wish Apple had an easy to find guide to do this, but they stand by their word that you cannot connect to the OS 9 computer. Way to go Apple!
