tide me over till DX10
EchoMatrix
thinkin of buying a system from dell and here are the options.
7900gs +$150
x1300 pro +$0
7900gtx +$500
Yeah yeah I know I could just make my own system, but i lost my stomach for building a computer after my last beast and everything breaking down on me. Yes I'm a pansie, but I want the ability to say "I HATE THIS THING. TAKE IT BACK" and dell will provide, without cost.
anywho. with 2gb of 667 ram,
core duo 2 (2.4ghz) and
2x 500gb hd and
heres the question. I know DX10 and vista are comming out, so I need something to tide me over till then. DUnno if i'm gonna get vista in the next 6 months, but if I do, then all I need to do is upgarde my video card.
If I have an old computer, dont remember specs, but it has a 6800, which one would be the best to hold me over for 6 months and play HL2E1 an episode 2? checking specs, it looks loke getting the GS would be the best for me now. Im leaving the area for 3 weeks then comming back and buying it then. So help me out here plz.
thankls
also im thinking about getting a 2407WFP i think its called. the 24 inch dell widescreen. I play on playing at the regular rez for that screen and everything turned on cept maybe all AA
maybe I should keep the 2007wfp?
yet ANOTHER note. If I go AAFES, I can get teh
256MB nVidia Geforce 7300LE TurboCache
is this sucker integrated? Can I just upgrade the card after I buy it with like a xtx or something?
First off, if you want to play at the native res of the 2407 you might want to consider the 7900GTX, then again you also might want SLI for all the bells and whistles. The 7900GS should play fine on the 2007, i believe. Again, not turning up the AA or anything as such.
what about just getting the LE, ripping it out, then putting in a x1900 in or so? worth the hassle?
if u go ATI, be sure that Dell has enough power. They are power hungry VC's with high amp needs.
375 Watt enuff?
It says it can handle the GTX, but they might upgrade the power supply for that one
again, it's not the total watts u need to look for. It is what your 12V Amps are putting out that is important. I think for the 1900s, you'll need a psu with 12v amp hovering around 30ish. Or you can get a PSU that has dual rail 12v lines that together equal around the 30amp mark.
If you don't buy the viceo card frrom dell, you could save 200. You can get a gtx from newegg for 300 and all you have to do is stick it in the slot.
