ti4600 rma'd still crashing
P3N1X[H]
basically i got a 4600....they sent me a 4600 instead of a 4200, i cant complain. but i can when its shipped to me DOA. so i RMA it to leadtek and they 'fix' it, and i get it back. and its working, displaying that is. it wont even complete a run of 3dmark03, it wont run the nvidia demos for that card, the wolfman, squid, and tidepool...they all error out.
i sent the card back to repair, and i get it a week later back, same card, but noticably new things soldered on. it will post, display, boot etc, but when i run 3dmark it will lockup freeze hang and eventuall,y crash out. even the nvidia demos crash..
it cant be heat because the heatsink, although warm isnt HOT. so i know its cooling ok.
im wondering about the driveres, im using the latest nvidia 71.89_win2kxp_english.exe package...maybe i should go back to older drivers? not sure, but im goin to try
just wanting to vent a bit. since i was shipped the wrong card, they wouldnt take it back and it was dead, so i rma then i get the same card back, and its working, if u call that working. but i cant do any intense 3d cuz it will crash out...
so grrr again, i send leadtek another email about this situation and im waiting on their response. but i can say that leadtek was VERY speedy and helpful for the initial RMA, so with that i am pleased. but now lets see where this goes.
funny enough. the current system im doing my testing in is a ASUS p4pe-x, and in the bios there isnt any option to disable fastwrites....so im kinda stuck, since i dont have any boards to currently use other than this on my test bench.
thing is i get graphical like lines and corruption erven in the bios, letters are all off looking. even the start key in windows is all weird looking. but for the most part gfx are ok, but now when it gets to windows, it will lock up and not respond to anything
funnily enough in safemode it will work perfect, no locking or graphical glitches...
I actualy herd and my brother owned a 4600 at one point, it was pure ass IMO, would lock up in halo, would give lots of artifacts (non oc'ed) and such......my other brother had a ti4200 that seemed to work just fine very stable.......i herd from other reviews the 4600 line just wasnt up to par with the 4200 and the 4800 was it? anyhoo, sorry its messing up, and i can tell you from experince my own 9600 pro, enableing fast write sucked ass in games :(
good luck tho!
soulsaver_8229
heh, well believe mne i didnt WANT the 4600
i ordered a 4200 64mb, they send me a 4600128mb, and then they wouldnt rma it for me or exchange it they just ignored my calls and emails and such, so i said fuck em...dumpinggoods.com i wont buy from them again.
so i RMA it to leadtek, its the Winfast A250 to be exact...
it was rma'd, repaired, then sent back to me...its not repaired by any means, i figure they resoldered some stuff, and send it back out i mean it wont even complete 1 cycle of 3dmark03 or even the nvidia demos like tidepool, wolfman, or ther squid...i just want this thing to work, and i figure im goin to have to RMA it again.
youd figure theyd test these things b4 they send em back out, like loop it on 3dmark or aquamark for lkike 24hours....borked!
Do you have another motherboard, and perhaps another power supply? It sounds like 3D mode specifically is what gives it problems, and 3D mode draws substantially more power. I'd say that's a candidate.
ok, i put in a bigger PS...400watt...
dont have a spare board at the moment.
it will boot into windows, and freeze at the login screen where i type the PW after about 5 seconds
i can however run it in safemode no problems. it wont lockup, it wont freeze...
what would this mean...im figuring since it hasnt loaded the gfx driver this could be because its not using anything 3d or whatever....im gonna unload the drivers, and try with the latest nvidia drivers
*frustrated*
*UPDATE*
put in a 400W PS, and wiped out the leadtek drivers. then installed nvidia laterst whql ones. and same deal it will boot...load to windows, then it will freeze at the login screen.
it also displays graphical tearing in the bios screen and in the windows boot screen, and on the pci device listing theres lines vertical up and down the screen , like tearing and checkerboards.....im just guessin the card is borked and it will need a 2nd RMA
