TI 4800 or 5600
Wicked_Bass
Which one would be good for a little while I save for a newer card!
thanks, Wicked
I'd not buy either and use that money to get your newer card faster ;)
What is the price range you are looking at? If you are looking between $100 and $150 there are a bunch of 9600 Pro video cards for under $150.00. Unless your card is really old I would wait and save. There will be some great deals by the end of the summer.
how much are you paying for the ti4800 or 5600, this will help us give you a rec.
you can get a 9800pro 128mb for like 180$....you cant beat the price/preformance ratio with that.....i tihnk its a refurb tho....still....id go for that....
The 5600 is a 256mg 128bit from gainward 88$
the 4800se is 128meg from gainward $88
Thanks
Since it's just a temp card, maybe snag a used GF4 Ti, 8500, or 9100 from the forums or eBay?
Otherwise, I'd say the 5600. If you can get one cheaper w/ 128MB I'd do that though. 256MB is a waste on that card.
here jsut get a 130$ radeon 9800 128mb....should be sufficient for a while
That's got to be a slow SE. Though if you get a moddable one you can turn 'em into pros...
I just sold my 256bit one for that.
