I need to get rid of two old CRT monitors. If you want them you can have them if you can come pick them up. The location is in the Bronx.
The two monitors are:
Dell P990 19": Last I remember the image was slightly fuzzy.
Sony CPD-E500 21": Had a problem with brightness but was solved with COM cable and Sony software. As a plus all the monitor internal values can be adjusted using the COM cable and the right software. This wasn't my personal monitor so I can't tell you if there's anything else wrong.
If nobody is interested, I will just dispose of them.
