ThrottleWatch question?
sp4rt4n85
I just downloaded the new 2.0 version of ThrottleWatch and this is the first time I've ever had a CPU throttle monitoring program. I was just wondering if its normal for CPU Load to be at 100% all the time? Also my CPU frequency is at 2010 Mhz and my CPU voltage is at 1.500v. I would appreciate your insight.
Wouldnt Have Thought so....
My CPU loads usually around 0 - 5 % when in idle or net browsing....
Not sure in games....
Hit CTRL+ALT+DELETE, It will tell you your Load in there under the processes Tab..
Someone correct me if im wrong :)
Pugz
Nevermind I figured why its running at 100%. Im using the Folding at Home program which is why its always running at 100%. Thanks for the advice.
