threw together build for my dad
hoek88
Web Browsing mostly but my dad thinks he will be interested in playing Eve Online or maybe a Call of Duty-esque game.
Preferably under $800
Conneautville PA
Motherboard, CPU, Graphics Card, Memory, HDD, PSU, Case
NONE
6) Will you be overclocking? No thanks
7) What is the max resolution of your monitor? What size is it? 20" 1920x1080
8) When do you plan on building/buying the PC? Immediately
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Don't care about SLI, but SATA 6gb/s would be nice, onboard video not a necessity
I have an extra 64 bit windows 7 he can use
So far I have,
MOBO = ASUS H110M-A D3 LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 uATX Intel Motherboard
CPU = Intel Core i7-6700 8M Skylake Quad-Core 3.4 GHz LGA 1151 65W BX80662I76700 Desktop Processor Intel HD Graphics 530
Graphics Card = EVGA 02G-P4-3753-KR G-SYNC Support GeForce GTX 750 Ti Superclocked 2GB 128-Bit GDDR5 PCI Express 3.0 Video
Memory = CORSAIR Vengeance Pro 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMY16GX3M2A1866C9R
HDD = SAMSUNG 850 EVO 2.5" 500GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E500B/AM
Case = DEEPCOOL STEAM CASTLE M (BLACK) MATX / ITX Unique Steam Punk Style with120mm Fan(Front) + 120mm Fan (Rear) + 4 Magic Controllable LED Lights (Top)
PSU = ??
Is 400w enough to power all this??? I couldnt find a PSU that produced more..
will the CPU and memory selection be Okay?
also the mobo and xfx card be compatible?
Thanks for any help!
I don't see why you think the case can't fit a PSU larger than 400w. It's a huge case, with room for 320mm long graphics cards, and a 200mm tall CPU cooler. There's even room for massive 1000+w modular PSUs
For a gimmick case, it's pretty well laid-out :)
I think you have the CPU and GPU costs balanced in the wrong directions. Also, your choice of DDR3 is INCOMPATIBLE with your build.
Let me give it a go.
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($194.99 @ SuperBiiz)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard ($84.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($49.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($148.89 @ OutletPC)
Video Card: MSI Radeon R9 380 4GB Video Card ($199.99 @ Newegg)
Case: Deepcool STEAM CASTLE M_BLK MicroATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($51.99 @ SuperBiiz)
Total: $780.83
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-05-18 17:30 EDT-0400
Unfortunately, in your original parts list the RAM and motherboard (not the Asus H110 one that you mentioned, but the MSI H170 one the Newegg link actually directs to) are not compatible at all with one another. (By the way you linked to the wrong motherboard when you made your original post.) That particular H170 motherboard requires DDR4 RAM (up to DDR4-2133 speed; faster-rated RAM will run at DDR4-2133 speed) while you picked DDR3 RAM. And although there are LGA 1151 motherboards that support DDR3 RAM (such as that Asus H110A-B3 motherboard that you intended to link to, but you instead put down the wrong item number in the Newegg link), officially Intel supports only DDR4 or DDR3L (1.35V or lower voltage) memory in its Skylake CPUs. That Vengeance Pro RAM is a 1.5V kit, which may be too high of a voltage for Skylake even if the motherboard supported DDR3 RAM. What's more, the keying and pin layout are completely different between DDR3 and DDR4 RAM: Your chosen memory will not even physically fit the memory slots on that H170 motherboard.
One further warning about Skylake and Windows 7:
You must have a PS/2 keyboard, a PS/2 mouse, a motherboard with two PS/2 ports or a motherboard with one PS/2 port plus a PS/2 Y adapter and an internal SATA DVD drive in order to install Windows 7 on a Skylake platform PC. Windows 7 cannot be installed on a Skylake PC if you have only USB peripherals and/or lack an internal DVD drive since Windows 7 lacks native XHCI (USB 3.0 compatibility) support while the Skylake platform does not support legacy EHCI (USB 2.0 compatibility) mode in its USB controller. (If you do attempt to install Windows 7 on a Skylake PC, none of your USB devices will work at all during the setup and installation process; therefore, if you have only USB input devices, setup will be permanently stuck at the first screen that reads "Install now" with a clickable button over those words - and the only way to solve this would be to completely unplug the PC to power off.) If for some reason you have only a USB keyboard and mouse or you intend to install Windows from a USB flash drive, you're stuck with Windows 8.1 or Windows 10.
You know, I completely forgot to include this in my Skylake build last night. This officially supported tool gives you native USB 3 support on Windows 7 installs, because companies sticking with Windows 7 for a while complained so much! :D
Download Windows 7* USB 3.0 Creator Utility
You should bookmark this too Eagle, because it's not well-advertised on the web.
