dolphumous
- Jul 6, 2004
1. Mic no worky...I'm using 5.1 so it's plugged into the front. Using Mic2 in the input options...can't get it to work
2. ICE isn't flat. I can't get it flat. it seems to be a little higher on the PSU side. With or without shim. That side is just sitting higher. But all in all it's fackin hot. [dremel in hand]
3. Nvidia System utility doesn't show the CPU and system temps. It did with my NF7-S. I didn't have to reinstall windows. I just put my HD in my new setup and it installed all the drivers. New board and old board were nforce2 ultra 400 and went from a 9700 pro to a 9800 pro.
Help?
NEW PROBLEM: When restarting it freezes on the POST screen. I have to shut it down for 10 seconds and turn it back on,
-Randy
Help?
-Randy
