Three pin power LED cable?
Skaladis
Hi, I'm currently building a computer. My motherboard has a two pin layout for the power LED cable, but my case has a three pin LED cable, the cables are in positions 1 and 3. What should I do about this? I've tried pulling the position 3 cable out with no success, and I'm not sure if I want to hack the connector up in order to plug it in, but I will try if it is necessary. Thanks in advance.
EDIT: Nevermind, I separated the connectors.
the spec for the connector is the pin 1 is Vcc and pins 2 and 3 are both GND. If you've got 2-pin on the mobo and 3-pin on the cable, then just move the GND pin from position 3 to position 2 and it'll work just fine. You'll just have the "extra" position dangling out in the air.
Yep . . . Just move pin 3 to slot 2 :). However, don't just yank out the pin. There's a small clip on the black housing which secures the pin. Use a tiny flat head screw driver or the end of a small zip tie and pry the clip up gently. Once it's up, the pin will slide right out :).
