Three new hard-drives - What programs to test them out?
Seraphic
Hi,
I have three new WD OEM hard-drives, and wanted to know, what programs I can use to test them out?
To test of bad sectors, write errors, seek errors, and any anything else needed.
Thanks
Christopher,
I have a question. Say you get new drives and you do the process you mentioned. Do you hook the new drives to an old system and preform you diagnostics or do you run them via a DOS prompt?
I never thought about doing what you mentioned.
Usually I do the full zero fill and media scan on a seperate system first because it can take about two hours per drive. Then I install them in their new home after they have passed the initial media scan. Once they have been installed in their new home, I partition/format/newfs them and put them into production.
dumb question, did the full zeros, what is the media scan? the extended test in the wd software or something else?
edit: i guess clicking it tells me, lol
