sharknice
- Nov 12, 2012
Competitive Gaming and AI development.
Around $3k USD more than I've already spent. I don't really have a set budget
USA, close enough to MicroCenter but I'll probably be buying most of it from Amazon
CPU, CPU cooler, motherboard, memory, storage, case, power supply
I have a GeForce GTX 1080 Ti with the SC2 Hybrid cooler modification. I'll also be putting a GTX 650 Ti in to run some extra monitors. I might also pop in a third or even fourth low end card to run additional monitors.
6) Will you be overclocking?
yeah
I have 8 monitors, main display is a 2560x1440 144hz gsync
in a month or so when AIO coolers specific to threadripper are available to buy
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
It needs to be able to handle 4 big video cards, 10 gigabit ethernet without having to take up a PCI slot
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yeah Windows 10 pro 64 bit
https://pcpartpicker.com/user/sharknice/saved/#view=2JVdCJ
I tried using PC Hound but it didn't have several of the parts
CPU
AMD - Threadripper 1950X 3.4GHz 16-Core Processor
$999.99
I'm pretty set on this. My AI said it needs more cores.
CPU Cooler
Enermax - LiqTech TR4 360 102.2 CFM Liquid CPU Cooler
not available yet, supposedly will be $150. I want an AIO cooler with full coverage for threadripper and this is the only one I know of on the horizon. If there is something else better I would consider it. I don't want to do full on custom water cooling. I'm pretty much waiting for this to be available to purchase before I buy everything.
Motherboard
ASRock - Fatal1ty X399 Professional Gaming ATX TR4 Motherboard
$433.98
I want this because it has 10 gigabit ethernet without having to use a PCI slot. It's the only one I've seen that does that.
I need to be able to fit 4 video cards in there
Memory
Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory
$324.99
32GB should be enough and since it's just 2 sticks I could add more later if it isn't. 3200 seems good but I don't really know if it makes a difference. Should I go higher or lower to save money?
Storage
Samsung - 960 EVO 1TB M.2-2280 Solid State Drive
$429.99
Will run the OS and some games
2x Seagate - BarraCuda 4TB 3.5" 5900RPM Internal Hard Drive
$108.79
$108.79
One for games and applications that won't fit on the SSD and another for large video files
Video Cards
EVGA - GeForce GTX 1080 Ti 11GB SC2 HYBRID -actually a 1080 ti FE that I installed the sc2 hybrid kit on
GTX 650 Ti
potentially 2 more video cards
$0, I have them already
My main display will be driven by the 1080 ti, but I have 8 monitors so I need additional cards to run them.
Case
be quiet! - Dark Base Pro 900 w/Window (Black) ATX Full Tower Case
$238.99
It seems good, I need room for 2 radiators for the GPU and CPU AIO coolers. If you think some other case would be better let me know.
Power Supply
Corsair - Professional 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
$242.82
Needs to be able to power threadripper and 4 video cards
Any suggestions are welcome. I think everything I picked out is compatible but it would be nice to get some verification.
yeah
CPU
$999.99
CPU Cooler
Motherboard
$433.98
Memory
$324.99
Storage
$429.99
$108.79
$108.79
Video Cards
GTX 650 Ti
Case
$238.99
Power Supply
$242.82
