thoughts on this upgrade?
Zencyl
programming, web, email, light serving, vm's, programming, gimp, everything else
~500
3) Where do you live?
great state of Texas
CPU, MOBO, RAM
Video, HDDs, PS, Case
6) Will you be overclocking?
probably
dual 20's
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
nothing specific
fedora (probably 64bit) and mixed linux vm's
These are the parts i came up with. Im not sure if the cpu is overkill, as stated above this machine will be multi tasking (running a few vms, web browser, coding projects, email, some terminal apps, i ssh into it, and what ever else
cpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
open to thoughts or suggestions, these parts are in no way set in stone, i was just getting a feel for what i think i need from newegg.
thanks yall
Look for a combo deal with the Phenom II X6 1055T and a Socket AM3 8-series chipset, like:
$290 - X6 1055T and Asus M4A88TD-V EVO/USB3 combo
(Better combo deals should arrive starting next week.)
The two additional CPU cores will really help you with your VMs and GIMP. If you're really serious about your multi-tasking, you may want to double the RAM as well. (Yeah, you picked a good set of RAM.)
