I've been meaning to get a zoom lens for my Digital Rebel and right now this one is looking about right.
http://focuscamera.com/prods/226523084.asp
[TQ] said:That is a very popular lens. It's going to produce decent shots. It makes the average user happy.
Check out pbase.com
Go to search
Camera
Canon
Then find the lens, it'll show you some example shots.
In my opinion though you'd be a ton better off getting the 70-200 f/4 L.
It is a much better lens and only a fraction more $ wise.
FLECOM said:is image quality of concern? will you be using it outdoors? indoors? lots of light? low light?
if you dont mind loosing a little on the long end you can get a 70-200 f4 L lens for about $100 more and the iq and build quality of the 70-200 is worlds better than the 75-300 IS... of course the IS is nice for indoor / low light shots...
depends on what your needs are![]()
Joony said:Do you guys believe that the 200mm end of the 70-200mm F/4L lens can reach far enough for sporting and wildlife photography?
[TQ] said:Wild life is iffy, but sports...heck yeah depending on your access
www.questphotos.com/football.
The truth is that a lens is not something you should feel like you'll be getting rid of some day. When you buy a lens, buy it because it's a wonderful tool that will work for years to come.
In the end you'll be happier, and save more money.
mdude85 said:it doesn't look like it reaches nearly far enough in those football pictures ...
Joony said:[TQ], wow, the 70-200mm F4/L looks very sharpare the pictures above 100% crops?
[TQ] said:Do explain...
Instead of posting a load of negative crap...why dont you go play in the sand.
mdude85 said:or posting a load of pictures in hopes that people will be impressed with them?
[TQ] said:I try to avoid the idiots...i'm adding you to my list.
I posted the pictures to show that 200mm is quiet close.
The photos them self pretty much suck, if you'd like me to critique myself i'd be glad to...however, if you recall i'm gonna try not talking to you anymore because...your an idiot.
