Thoughts on Silverstone TJ-07
ArrowMk84
I'm looking at buying a Silverstone TJ-07 to replace my Coolermast Stacker 810, and I wanted to know how easy it is to work in and route cables, without having have to make major (ie cutting) mods. Thoughts?
I just posted a similar question, trying to decide between the TJ07 and the Lian Li PC-V1200.
I went ahead and ordered the TJ07 (I figure I have till Monday to cancel, if someone has a good reason to not get the case). Looking at its pictures, it will be better than more current case.
I had the V1200 when I built this rig, but it didn't too good a job air cooling my PC, and I had to pull out the bulkhead in the PSU compartment to get my PSU to fit in it. IIRC, I couldn't hid cables under the mobo "tray", because the support bars went flush against the side panel. It was an alright case, but I wouldn't get it again.
I wish I still my old Tornado case. I could hide wires in that thing with no problem, and it cooled like a dream.
dont worry, the TJ06 is a great purchase IMHO
edit: i meant TJ07, i just typed 06
Yes, it is.
As is the TJ07 that he actually bought.
About to pull the trigger on one myself.
The TJ07 isn't that bad. It's no Stacker 810 but I'm not that displeased with the one I've got sitting next to a Stacker 810. Seems to keep the innards reasonable cool (compared to my stacker with similar innards) with the addition of a Skythe 120mm drive bay fan gizmo (thanks to a post here for pointing that gizmo out). I'd buy another. Especially if the price dropped.
get right angle sata connectors, the case doors push up against regular ones and split them in two!
shady06 said:
it is the best case out there right now
Fixed :cool:
Anyways, I love mine, I also love my TJ06 and the 810 Stacker... all 3 of them are awesome cases.
