thoughts on kingwin a3000
I'm looking at using this system for a client that wants liquid cooling for noise reduction only. I know, but this is what they want. Anyway, the case is a TT Tsunami with the door closed on the front. I'm wondering if anyone has tried anything like this. I want to know how the closed door affects the units ability to remove the radiator heat. Amny thoughts? (other than don't do it. LOL)
i used the old kingwin kit AW1c....it worked fine....was still loud when you turned the fan up...but compared to what i run now...it was quiet......so meh...i would talk them into a better system, like something swiftech...or a dangerden setup...mainly because Kingwin doesn't have the best quality control :/..but either way...there is maintenence involved...i hope you've told your client that.
