Thoughts on forcing 100% CPU usage in Ubuntu?
musky
[H]ard|DCer of the Year 2012
My 4th I7 is not consistently loading all 8 recognized cores. It usually has 7 cores loaded close to 100% and the 8th runs close to 0%. The unused core changes fairly frequenly. As a result, my last several frames of my current bigadv have taken close to an hour each. The main difference between this one and the other 3 are 9.10 Desktop with the GUI running instead of 9.04 Server and this one connects with a wireless card instead of a wired connection.
I changed the nice level to -1 for all core processes and the executable, but I am still seeing the same thing. I am thinking this is yet another 9.10 process handling issue. I am going to try to shut down the GUI if I can figure out the wireless and see if that helps. Any other ideas? This one has me stumped.
Interesting situation/question. I've never seen this, but I am using 8.04 in my Big Adv VM as I don't have greater than 8 cores yet.
Switch back to 8.04 server unless you desperately need the GUI, eg. if it's your primary rig. Otherwise, just scrap it.
You are going to want to go with 9.xx if you ever run more than 8 threads.
This is my main rig, so I kinda need a GUI. Shutting down the GUI does seem to solve the problem, but I can't get the wireless connection to work without the GUI. I can't seem to set the essid on the wireless adapter from the command line.
Set the processor affinity of each process so that they're all on separate CPUs. Install 'schedutils' package (might come with the distro) then
Code:
taskset -c <processor> -p <pid>
Processor id starts from 0, you can get the pid from ps or pgrep or the system monitor or whatever.
Update:
Ubuntu 10.04 doesn't fold at all yet - some dynamic libc issue - looks really nice, though.. :)
Ubuntu 9.04 - so far, so good - all cores at or around 100%, we will see how frame times look
Another fun evening with Ubuntu....
Ubuntu 9.04 - so far, so good - all cores at or around 100%, we will see how frame times look.
Definitely let us know your thoughts on U9.04. I'm thinking of trying this as my next Linux distro experiment.
31:20/frame - not bad for an I7 @ 3.64.
Code:
[03:55:14] Completed 0 out of 250000 steps  (0%)
[04:26:43] Completed 2500 out of 250000 steps  (1%)
[04:58:01] Completed 5000 out of 250000 steps  (2%)
[05:29:19] Completed 7500 out of 250000 steps  (3%)
[06:00:39] Completed 10000 out of 250000 steps  (4%)
[06:31:57] Completed 12500 out of 250000 steps  (5%)
[07:03:19] Completed 15000 out of 250000 steps  (6%)
[07:34:45] Completed 17500 out of 250000 steps  (7%)
[08:06:03] Completed 20000 out of 250000 steps  (8%)
[08:37:25] Completed 22500 out of 250000 steps  (9%)
[09:08:43] Completed 25000 out of 250000 steps  (10%)
[09:40:03] Completed 27500 out of 250000 steps  (11%)
[09:53:29] - Autosending finished units... [April 7 09:53:29 UTC]
[09:53:29] Trying to send all finished work units
[09:53:29] + No unsent completed units remaining.
[09:53:29] - Autosend completed
[10:11:27] Completed 30000 out of 250000 steps  (12%)
[10:42:45] Completed 32500 out of 250000 steps  (13%)
[11:14:07] Completed 35000 out of 250000 steps  (14%)
[11:45:26] Completed 37500 out of 250000 steps  (15%)
I'll crunch some numbers on these and add an update on recommendations for a starting point. I am thinking that 9.10 Server is the fastest (PPD/MHz) distro I am currently running, followed closely by 9.04 Desktop. 9.04 Server is lagging behind, but not terribly.
