I was browsing the DoubleSight website and stumbled upon this. I used the search function as well as Google extensively and couldn't find a thing about this monitor. It says it's a 2009 release - so is this monitor brand spankin' new?
The specs seem pretty hot and I'm tempted to buy this if it doesn't have any glaring issues. Any guinea pigs want to test drive it?
Here's the stats from the DS website:
"New for 2009, the DS-2700DW is the perfect large LCD Monitor for a variety of applications.
The DS-2700DW Monitor is HDCP (High-bandwidth Digital Content Protection) capable to ensure that you are able to view Digital Content with the crisp clear images you expect.
The DS-2700DW provids a full compliment of input options. DVI-D, D-SUB, HDMI and Component inputs are all avaialble to make it easy to connect your PC, Game Console, Blue Ray Player or other device to the monitor for easy viewing. "
Display
Panel Type
:S-PVA
Viewable Area
:581.78mm(H) x 363.06mm(V)
Display Colors
:16.7M (8 bit)
Pixel Pitch
:0.303mm x 0.303mm
Max. Visible Angle
:178º/178º
Response Time
:6 msec (GTG)
Brightness
:500cd/㎡
Aspect Ratio
:16:10
Contrast Ratio
:1000:1 (DCR 3000:1)
Recommended Resolution
:1920 x 1200 @ 60Hz[/SIZE][/SIZE]
Display
Panel Type
:S-PVA
Viewable Area
Display Colors
:16.7M (8 bit)
Pixel Pitch
:0.303mm x 0.303mm
Max. Visible Angle
:178º/178º
Response Time
:6 msec (GTG)
Brightness
:500cd/㎡
Aspect Ratio
:16:10
Contrast Ratio
