I'm one of the people who has enough knowledge to get myself into trouble and I thought I'd share my recent experience. I had a Phenom II 965 BE and an ASUS M4A89GTD PRO/USB3 board. After doing some research I decided to do a switch to Intel for an upgrade. No slam on AMD, it was just evident that AT THIS TIME The Sandy/Ivy Bridge Cpu's are better performers for gaming and games are my most demanding applications.
I am not into benchmarks, what I care about is real world performance, and the only"benchmark" I have used is the WEI. I know this is a rather poor and general benchmarking tool but it is at least an indicator. Recently my wife's laptop died and I bought her an ASUS G75VW-TS71. Right off the bat I noticed that she got a better score in WEI on cpu and memory performance than I did on my gaming rig. This was even though her cpu was not rated to be as fast as my 965 and her memory was 12 gigs of 1333 vs. my 16 gig of 1600. So after doing some research and asking for opinions on the H
I ordered an I5/3570K and a Gigabyte GA-Z77X-UD5H.
The physical installation was no problem and I was pleased that there was just enough extra clearence between the ram sticks and my heatsink to slide the fan all the way down to where it should be. Previously I had to slide it up about a half inch. But both my DVD drives were EDI and the board has no provision for this. Uh Oh....I had no way of running the disc with drivers and utilitys. I tranfered the files to a thumb drive but the system either would not boot or would crash if it did boot. Sometimes it would crash almost immediately, once it ran for about an hour and a half. I got a Blu-ray drive and installed it a couple of days after. When I went to start up I took another look in the bios and saw that by default it was set to run the Ram in Turbo mode and for some illogical reason decided to switch it to normal. Voila....the system booted and has since run like champ. The board was reading the ram at 1333 so I manualy set it to 1600.
Here is the kicker. Running at stock clocks the CPU scores a 7.6 on WEI while my 965 scored 7.4 even overclocked to 3.8. The same Ram that scored 7.6 now scores at 7.8 The 965 would Idle at 32c with cool n quiet enabled, the 3570k idles at 22c. I have not seen it go above 40c when gaming whereas the 965 would hit 48c.
I'd like to thank the people who gave me a hand when I asked for help on the Intel motherboards forum and the Intel cpu forum here on the H. You came through for me with helpful suggestions and advice, and generaly kept me from losing my mind when I could not get this rig running. Glad I joined the Hard Forum.
