Steel Chicken said:ive been looking at a similar but stripped down setup.
same mobo, 2 GT's instead of ultras,
246's instead of 250's
2 GB instead of 16GB
2 raptors in raid for OS
and 2 other big drives for data
but, even stripped down, its just too much cash
$3.5K
supposedly, the mobo allows for some minor OC'ing, but details are not available yet
elfletcho said:Raid 0 is faster than Raid 5. Sure it is way more prone to crashage but if he is lookin for speed that is the best way to go.
jacuzz1 said:You are of course correct however what does that meam? Once every 3 years as oppposed to 5? I have been using raid 0 arrays for two years and never lost an array. Ok once when a hitachi died butit was an array that was 10 minutes old. lol
True that.ikari303 said:I'm simply saying that especially if he's doing all that "medical imaging" then I really wouldn't want to risk it across a 4-drive RAID 0.
aNtHrAx323 said:He said he wanted "balls-out ridiculous hardware", so that's what I did.
Trepidati0n said:Nah....I'd be willing to bet that most of the data on his harddrive is moved on and off pretty quickly. I wonder how much space a whole human body takes up in terms of data for an MRI; a few 100 GB is my guess. So if it craps out...it probally doesn't phase him much. Ifhe is smart he'll create an image of the OS as backup.
-tReP
furiousfords89 said:with all the money spent on that killer rig, i would much rather buy myself another car with the 8+ grand used to build that comp.![]()
elfletcho said:Ditto for me, my two disk Raid 0 array has never gave me trouble (knock on wood). Just saying that people (read that as kids thinking they know everything) always try to push Raid 5 saying it rocks, when it really is quite slow. If you want speed and protection, you might was well just go Raid 0+1 if you have the cash.
genmae said:RAID 5 has the highest read speeds. Seeing as to how people tend to favour RAID 0 for "speed" ie. fast reads, fastest writes, it is incorrect to say raid 5 is "quite slow." Indeed, write speeds for RAID 5 is slower than 1 and 0, but it is not "quite slow," especially in a proper hardware driven array. You should inform yourself properly before putting things down.
on linux and such(atleast on knoppix) you can at boot order it to load os to ram module so im sure you could do this....god imagine a huge ass cluster with 120GB of ram that let u multitask with everything in ramDr. X said:Hmm...I wonder if there is any way to setup a virtual ramdrive the way hibernation works so when you turn off your comp it writes everything in memory to the harddrive.
Ballz2TheWallz said:on linux and such(atleast on knoppix) you can at boot order it to load os to ram module so im sure you could do this....god imagine a huge ass cluster with 120GB of ram that let u multitask with everything in ram
elfletcho said:That is what I was guessing. He just needs the speed to swap out huge amounts of data from his HD's constantly. Not much of a need for secure data.
No need for an apology. Anyone on this forum that has objected to your system either can't use or doesn't know how to use the processing power or can't afford it.venturi said:I apologize if the pc did not meet with everyone's approval, I had intended to build it for myself.
$480 - Tyan S2895A2NRF - No SCSIWashuu said:I have been looking at that motherboard since late november @ 2cpu.com .... it's just beautiful. I still want to know how much the motherboard costs, it was originally estimated to be almost $700 alone or more. ( it has an onboard SCSI controller, along with everything else )
BossNoodleKaboodle said:The hospitals have dedicated lines by which they can access those huge files remotely?
venturi said:wow computerpro3, that's a greta slide.
PACS is a primary role for this type of machine. Yes I have huge SANs holding the core data in some hospitals. On average a regular large hospital can pack away over 3 T a year from 130, 000 studies and /or 18 modalities.
new modality technology has also increased this number with larger adoption of 64-slice Ct and spiral MRI. MRI magnets are common at 3 tesla or more.
Small World
VENTURI
venturi said:Computerpro3
no... I work for myself. I have my own company, staff, buildings and resources.
I have "good" relationship with GE although........
VENTURI
