This is driving me nuts!
Jfkfhhfj
Hey, so i'm having a problem with my networking setup at home and i need a little help from you guys.
Simply, I cannot get my server to send outgoing traffic through my network. I.e. If i try to connect to any of my services i get a very weak connection. Now, i can still CONNECT, i just don't get any data flow. I cant even PING the server internally, it just times out.
Now, regardless of whether i use my internal IP/external domain, i get the same issue. I logged onto my computer and tried a speed test the download was normal (around ~20mbit) but the upload times out.
Heres the fun part, if i connect to the server using a switch, everything works fine!
Is it my router or some stupid configuration issue?
Router is a WRV54G (I hate this thing)
Server is running windows 2008 and has a virtual machine.
Let me know what you guys think, i cant seem to figure this one out...
Would there be a problem with the NIC setting even though i can connect fine through a switch? If so, how do i check, not used to doing admin stuff through windows, much more used to *nix.
Never mind, found it, set it from auto to full duplex 100MBPS.
Same shit :/
