Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The most common sizes for 120mm fans come in are 25mm and 38mm thicknesses. I dont believe they are made any less than 20mm for the most part. There might be a 15mm out there, but I doubt it very much, and if out there will be very uncommon. You can try to find a 20mm thick 120mm fan but they arent nearly as common as the most common size of 25mm. In any case, hopefully you dont need great cooling, because the thinner the fan, the lesser the air pushed through it in general. Good luck.
Yeah, 80X15's are fairly easy to get, Zalman sells one among others. A 92X15 is fairly rare. Who makes the 92X15 you have? Just curious. You never know when a need for one will turn up.
That must be a misprint, the Cornair-Rotron fan model CR040-ND (aka FL12E312) is made as a 120X25mm not 15mm. That page is incorrect. Besides at 15mm width it would have to spin hella fast to create 61CFM as it is rated.
