Thinking of making the switch
DlStreamnet
Just have a few questions;
My hardware is;
Msi K8n Neo 4 Platinum Sli
Amd 64 3000+ Winchester Core
1x 120gb Seagate
1x Msi 6600GT
1) Would this be a good system to cool my pc?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=80150&item=6760973638&rd=1
2) Would that be sufficient to keep my system cooler than what it is now (30 degrees web surfin, 37 degrees gaming [celcius of course])
3) In that kit, is that all I need?
4) If that isn't very good, what should I use?
Megadeth_Guy01 said:
That kit would most likely end up raising your temps.
Agreed. It might be quieter, but temps are almost guarenteed to rise over what you have now.
The Thermaltake Aquarius II just is not a very good w/c kit.
a signle 80mm radiator isnt going to compete with good air cooling
if youre going to cool just the proccessor, then at minimum you should use a single 120mm radiator
