black6spdz
- Sep 25, 2010
So I've squeezed all 4 drives in this mini ITX case "only has two internal 3.5" slots. I am actually surprised, it only draws 54 watts with 4 drives idle. It used that much power with two drives and the old C2D motherboard. So I setup the drives in Raidz2 and copied a large folder "130GB" of random stuff back and forth. It had no problems saturating the Realtek GigE >100MB/s on the large files both to and from the array with LZ4 enabled. it was right at 30 minutes both ways. I tested with the intel nic and it took 30 minutes to copy that data to the array and 24 minutes to read it from the array. With that being said, I'm still up in the air over using the Intel NIC OR installing the PCI-e SATA3 card and using the 60GB SATA3 SSD for L2ARC cache. Would saving reads to the hard disks improve longevity? I can see most of my daily working data fitting in this 60GB cache so it could be beneficial in that sense. I've run multiple passes of Seatools and MHDD on these drives so I trust them with my data.. I'm just waiting on this last question before I complete the setup and move my data over to this new box.
