Thinking of a upgrading
Soarin
Okay i am back in school now and back messing with computers all the time. So i am thinking of upgrading starting with mobo. Here is my current mobo.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444
Model
Brand
GIGABYTE
Model
GA-880GA-UD3H
Supported CPU
CPU Socket Type
AM3
CPU Type
Phenom II / Athlon II / Sempron 100 Series
FSB
2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge
AMD 880G
South Bridge
AMD SB850
Memory
Number of Memory Slots
4×240pin
Memory Standard
DDR3 1866(OC)/1333/1066
* To reach DDR3 1866MHz or above, you must install two memory modules and install them in the DDR3_3 and DDR3_4 memory sockets.
Maximum Memory Supported
16GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 2.0 x16
1 x PCI Express 2.0 x16 slot, running at x16 (PCIEX16)
1 x PCI Express 2.0 x16 slot, running at x4 (PCIEX4)
PCI Express x1
2 x PCI Express x1 slot (The PCIEX1_2 slot shares bandwidth with the PCIEX4 slot.)
(Note) The PCIEX1_2 slot shares bandwidth with the PCIEX4 slot. When the PCIEX4 slot is populated with a x4 card, the PCIEX1_2 slot becomes unavailable.
PCI Slots 3
Storage Devices
PATA
1 x ATA133 2 Dev. Max
SATA 3Gb/s
2
SATA 6Gb/s
6 x SATA 6Gb/s
SATA RAID
SATA 6Gb/s: RAID 0, RAID 1, RAID 5, RAID 10, and JBOD
SATA 3Gb/s: RAID 0, RAID 1, and JBOD
Onboard Video
Onboard Video Chipset
ATI Radeon HD 4250
Onboard Audio
Audio Chipset
Realtek ALC892
Audio Channels
8 Channels
Onboard LAN
LAN Chipset
Realtek 8111D
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
1
Video Ports
D-Sub + DVI
HDMI
1 x HDMI
USB 1.1/2.0
4 x USB 2.0
USB 3.0
2 x USB 3.0
IEEE 1394
1 x IEEE 1394a
S/PDIF Out
1 x Optical
Audio Ports
6 Ports
Internal I/O Connectors
Onboard USB
8 x USB 2.0
Onboard 1394
2 x 1394a
Physical Spec
Form Factor
ATX
Dimensions
12.0" x 9.6"
Power Pin
24 Pin
Manufacturer Warranty
Parts
3 years limited
Labor
3 years limited
I am thinking of these ones now, because of the chipset reviews I have read, I will be reading more into the 990 chipset and basing my final thoughts on performance for gaming, video editing, reliability and price..
http://www.newegg.com/Product/Produ...28-510^13-128-510-TS,13-131-754^13-131-754-TS
Also going AMD because of cost unless there is a better reason. IE Performance of comparable intel products at no much more cost.
What CPU do you have now and what are you planning on upgrading to?
+ What revision is that motherboard?
Do you have any tasks that requires more CPU power, or is this just a case of the upgrade itch?
Those boards add
SLI/Crossfire
potentially front USB 3.0 headers
Bulldozer support
potentially more OC headroom
Do you need any of these features?
Upgrade itch really. XD
Hmm I might just do plan B whihc is new power supply, more ram, more HDD. Better video card.
Oh should mentioned that I want hot swapable HDD. Cause the classes I am in could really use the nice feature.
Try posting in the general hardware section, remember the "answer these questions first" part including what hardware parts you have now, not their features, and you may get some good input to where you should put your money.
Given your current motherboard and CPU I have to say that they are close to the end of the road.
Unless you have some special purpose you might as well get a proper cooler and OC that CPU.
Buy new once the CPU cannot keep up with what you want and you can afford buying a new CPU and motherboard at the same time.
I know runs... That is why i compared the boards here. To see if anyone had some Knowledge of them, real world. My sig had my build in or it used too.
There is no need to upgrade your motherboard from 880 to 990 chipset except to support Bulldozer/Piledriver which those are not worth upgrading to from your current processor.
Basically, you have no worthwhile upgrade path at this moment in time without replacing both the mobo and the CPU for Intel. (unles you run specialized workloads where a Bulldozer excels)
On the other hand a Phenom II 945 should be able to do most things you want to do, so unless you REALLY need to upgrade your CPU I would look into upgrading other things first.
1) SSD if you dont have one.
2) Larger monitor/2nd monitor is always a worthwhile upgrade.
3) Better video card if you game at all.
4) Input devices (nice keyboard and mouse)
5) Good set of speakers if you like to jam out.
6) Good quality headset if you like to game.
Hope this helps.
I use a sharp Aquous for my monitor except I am hampering it bad, using a VGA cable, as my ex took my HDMI. Another reason I forgot to mention is that I am also going to be helping my brother out and giving him my board and memory because his took a shit. The cpu is good but the board went bad.
Also I have an SSD but i may upgrade that, I have a 5770. I have a logitech g15 KB and a m9 mouse. I have nice logitech headset USB ones.
So what I will do is get this thread closed and figure out a different avenue, because I really cant offered to drop 500 plus on that many new parts... Although i want the mobo to help my brother.
