Thinking about what to upgrade...ideas?
natermeister
I'm nearly done constructing my new gaming box, but I'm already thinking about what to upgrade, the specs are as follows:
AMD Opteron 170
MSI K8N Diamond Plus
2GB Corsair DDR 500
eVGA GeForce 7900GTX
WD SE16 250GB
Old Sony DVD-ROM
Even older Plextor 20x CD-RW
Lian-Li PC-V1100B
Silverstone 600W modular PS
Samsung 204B
The obvious things would be a DVD burner and a SoundBlaster X-Fi. I'm going to put down the money for the X-Fi as soon as I pay my lawyer(another story). I want to wait for a decent SATA DVD burner, right now Plextor makes the only one that I am aware of and it has several compatability issues.
I was thinking about buying another 7900GTX and possibly building a serious water cooling setup for the cpu, video card(s) and the northbridge.
Any ideas?
Thanks,
Nater
I would add another monitor. I could not function without my dual monitor setup.
Make sure you get a decent HSF (Ninja or 9500), that is, if you don't go for the water cooling setup.
The issue with getting another 7900GTX is that your native res on that 20' would hinder the true value of the second card. In my opinion I'd save the money and wait to invest in the computer until DX10 comes out. This way you've got plenty of performance now and you'll be ready for later.
If you are going SLI, read up on the XiFi as you may want to make further use of your lawyer to sue them lol
Theres a problem with some high end gaming machines and the XiFi.
Its to do with a resource being tied up for too long, possibly by the graphics subsytem, which causes the soundcard to stutter.
Creative dont have a solution yet and havent found all the ways it can happen. It has been a long running dispute.
This water cooling setup has been getting good reviews.
http://www.asetek.com/default.asp?s...=sideid&myvalue=14&contentSection=2&menuID=-1
it sounds like you want to build your own though so...
I have use the block in the top picture and its very good
You will have to find a supplier of the Block alone as Asetek dont seem to do them now.
Alternatively get the full kit with it in as its a good kit.
If you fancy a complete ground up approach:
The CPU Block is called the Antarctica. Be sure to get the 12mm version (not 10mm). note: the 12mm version uses 12mm OD pipe which just inserts into the 12mm ID piping (you should use for the system), it wont leak if you shove it in a bit. Clamp them a little with a jubilee clip or tie wrap.
Any big car heatercore is going to be a decent radiator. I would take some recommendations from Forums on what is best and where to get them.
I use a Ford Sierra (UK) Heatercore and its great.
You will need at least an Eheim 1250 pump if cooling the chipset/gfx/cpu. There are so many opinions on what is the best pump, my preference is to draw power from the mains not my PSU.
Mount fans in a sealed windtunnel box, at least a little distance from the radiator as it will increase efficiency and reduce noise.
I mounted a fan on one end of a box and the radiator at the other end.
I used a pipe splitter to refill mine rather than using a reservoir.
A reservoir will slow water flow and decrease pressure at the water blocks.
You may not be bothered by this if your pump is strong enough.
I dont know what would be a good GPU or chipset block as I havent researched this for some time, so reviews will help you.
Have fun!
